Right, following my bad ram stick episode, I've been able to clock this Q6600 up to 3.6 ghz quite easily. AndyOCUK had an identical setup to mine (bar gpu), and at 3.6 his rig ran at:
Vcore : 1.4475
RAM: 1.6
NB: 1.45
ram timings : 9-9-9-24-2T
I'm running mine with 1.5vcore, because I guess it needs more. Actual cpu-z is 1.55 in windows.
I'm getting idle temps of 35-40 and load of 50 during gaming, nearing the higher 60s during Prime95, even low 70s with Intel Burn Test.
I only want to use this pc for gaming, so are these temps and voltages ok for 24 / 7 use?
It is the 95 W SLACR edition with a thermal specification of 71 according to the intel spec sheet.
http://processorfinder.intel.com/details.aspx?sSpec=SLACR
Would a gaming max of 68 be ok? Or too high?
Thanks for any help.
Vcore : 1.4475
RAM: 1.6
NB: 1.45
