Q6600 temps ok?
5 Jan 2004
I've overclocked my q6600 to 3ghz, at 1.385v. When i prime it i abit guru tells me the temps underload are 68-69 and core temp tells me core 0 and 1 are 56 degress and core 2 and 3 are 49 (i tried to reseat heatsink 4 times but core 0 and 1 are always 5-6 degrees hotter the 3-4). i'm about 5 hours into prime the temps have been the same since 30ish secs into it (from 44 degrees idel guru and core 0 and 1 at 30 degrees, core 3 and 4 at 25 degrees idel core temp), i'm going to stop it after 8 hours (12'o clock). Are the temps ok if they stay the same?
I'm not as good. I'm 43-45 at idle at 63-64 under load but I do have my gts in the loop as well.
That's at 3.6Ghz and 1.5v - hence the high idle temps I guess?
