Q6600 Temps TJunction or TCase?
Ive done a bit of digging around the net to determine if my Q6600 is operating at safe temperatures and to be honest there's a lot of comments such as "I wouldn't feel comfortable with so and so temps" etc.
My question is not about what is comfortable as a matter of someones own opinion, but whether my CPU is operating within its temperature limits and at what point I should start being concerned.
I'm running a Q6600 G0 B stepping overclocked at 3.4 ghz at 1.4 volts. On top of it is a tuniq tower at full speed. Im iddleing at around 47c.
The PC is in a small-ish room with significantly high ambient temperatures. When I built the PC downstairs and moved the PC upstairs my temps rose by about 15c due to the ambient temperature difference.
When I run intel burn test my temperatures go up as far as 85c as reported by Core Temp which I believe measures the temp off the TJunction sensor. Is this a safe operating temp baring in mind intel burn test maxes out the system beyond my every day use inevitably maxing out my temps beyond their usual reading.
Ok so as said, current idle temperature is 47c as stated by Core Temp off the TJunction sensor and 39c as stated off the Easy Tune utility supplied by Gigabyte which I believe is giving me the TCase sensor reading.
At what point should I start being concerned about my cpu temps? I have an air conditioning unit which I run in the summer as the ambient temps are unbearable without it. I believe my ambient room temperatures would probably be lower in the summer with the air con on than they are now without the air con, so I cant see ambient temperature causing my temps to rise much come summer time.
