- 22 Nov 2007
I was monitoring my cores today and they seem to be around the 34-45 range when i was just doing downloading on steam, i figured this was okay i think? Then i ran prime95 on the first setting (lighter one). After about 30 seconds ( i think) maybe a bit longer all 4 cores were 80 + with the the 2 cores that are normally higher reaching 92. I quickly turned it p95 off as i got worried. According to coretemp the limit for the cores is 100 until they auto switch off. Anyway i take it this is not normal?
Forgot to mention im using the stock cooler and it has been ok for 2 years but i am abit alarmed with them prime 95 tests.
(G0 revision)
(G0 revision)
