Hi.
Im looking to upgrade my Q6600 to something with a little more grunt. I've found a Phenom2 1045t along with an asrock 970 pro3 motherboard for a little over £140 and wondered if it would be a suitable upgrade. It might be worth noting that i dont know much about how AMD processors perform, nor the Intel processors past the Core2 range.
My budget is £150 (i could maybe go to £170 if needed), im needing a new motherboard along with the cpu.
It needs to have ddr3 ram (most motherboards nowadays are, i assume), along with 2 pci-e slots for a future crossfire. Also, preferably quad core or more, but im open to being convinced otherwise for that.
Current specs are:
Q6600 w/ Corsair H60
G41MT-S2PT << i think this is whats holding back the overclock, but not sure.
4GB kingston 1333Mhz ram (upgrading to 8GB corsair vengeance 1600 Mhz)
Sapphire HD6870
128GB kingston SSD
1TB samsung H3
2x DVD-RW
OCZ gamexstream 600W
I'm not looking for the best of the best, i know £150 wont get me that, just something that will be enough for the next year or two. It's going to be a gaming pc mainly (again, not looking for maxed out settings for everything) along with video converting, and general usage (web browsing, word documents, etc).
Thanks.
Current specs are:
Sapphire HD6870
128GB kingston SSD
1TB samsung H3
2x DVD-RW
Thanks.
Spending 50 odd quid to gain 300MHz which doesn't make a lot of difference on a Q6600 is a waste of time n money.
