- 10 Sep 2012
- Bristol
Just pricing up options on upgrading a Overclockers PC i have had since jan 2008.
Its the one with the q6600 @ 3.2ghz
IP35 PRO motherboard
2gb PC8500 DDR2
768mb 8800gtx
Running vista 32bit
Antec 900 case
Upgrade Budget = £600-800
Would like to build into new case, re-using the dvd drive, using hard drive as storage secondary drive in new build and re-using power supply 650 watt corsair(only 9 months old)
I already have g700 mouse, g510 keyboard, working 1 year old Logitech 2.1 speakers, and a brand new Easter 2012 bought Samsung S23A350H 23 inch 1080p monitor.
Wont need Windows 7 as i can get that through my work.
Edit: would like new hard drive, and i will be wanting to run all the latest games on ultra with 40fps or more.
Thanks in advance.
2gb PC8500 DDR2
768mb 8800gtx
Running vista 32bit
Antec 900 case
Thanks in advance.
