Q6600 vs Q8300
20 Dec 2010
*First post*
Hey everyone
I bought this barebones deal from OCUK and I need to know what CPU I should get.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-269-OK&groupid=43&catid=1817&subcat=
I myself use a Q6600 but I could buy a better model and give the Q6600 to my brother and use the much more better one :P
I heard that the 45mn C2Q do not overclock very well compared to the Q6600.
Would Love your suggestions with regards to what model of C2Q I should get my budget is £120
If you want a 45nm C2Q then I would only consider a Q9450 or Q9550 as the Q8300 is a bit gimped due to only having a 7.5x multi and 4MB L2 cache. If you can't get either of those for £120 then I would just get another Q6600 and keep the change.
