Q6600 weird overclocking result
10 Nov 2006
Lincolnshire
Just got my Q6600 tonight posting nice and stable @ a stock 2.4 with orthos load temps of CPU 33c - Core0 33c - Core1 28c - Core2 24c - Core3 27c, are these o.k????
So I had a little go at overclocking her and I decided to start with 3.2.
Went ino the Bios entered 400FSH 1.375V and a multipler of 8 which should equal 3.2(Asus P5B deluxe).
Rebooted and noticed straight away on the POST screen it showing 3.6!!!!!
Went back in straight away as I didnt want to boot @ 3.6 with that voltage to see if my settings had been changed, and sure enough they had saved O.k.
I changed the settings to 400*9 and sure enough it posted 3.6 then back again to 400*8 and its still showing 3.6?????
Ive put it all back to stock for now to ask this question.
What do you think it could be, hoping I can still use multis of 8:eek:
A lot of aps won't detect a reduced multiplier and will think you're still using the highest multi.
CPUZ is your friend.
Jokester
I would have thought that ASUS could have managed to get their POST screen to show the correct speed.
If it's really at 3.6 with 400 x 8 then can only assume it's ignoring the multiplier change you made.
