q6600 with striker extreme
16 Feb 2008
Staffordshire
Ok,
thought I would have another go at OCing my PC again.
I have been running it at 2.7 for as long as I can remember, the fsb is set at 1200, I increased to 1400 and ok but had little gain in the cpu.
So I figure increase again as per suggestions from the forum in the past, as soon as I increase the fsb to 1600 it just hangs.
If I remember I ran it at 3.0ghz on a P35 board by just increasing the FSB.
Do you reckon its the Asus striker?
suggestions most welcome.
thanks
Hey
Ive had my E8500 @ 3.8Ghz for over a year, (maanged to bench it at 4.2Ghz)on my striker extreme.
I dismantaled it yesterday though to build a new i7 system. But here are my settings:
Unlinked
FSB (QDR) Mhz = 1600
MEM (DDR) Mhz = 800
VOLTAGES:
Vcore = 1.35v
Memory = max manufactor rated
1.2HT = 1.25v
NB Voltage = 1.35v (i needed a 90mm fan sat over the NB to keep it cool)
SB Voltage = 1.50v
CPU VTT Voltage = 1.25v
System clocks:
PCIEX 16_1 Frequency 101
PCIEX 16_2 Frequency 101
PCIEX 16_3 Frequency 101
SPP <-> MCP Auto
I set my RAM timings manually which were 4-4-4-12 (2clock)
This is my opinion only, but dont go over the below voltages.
Vcore = 1.45 max
1.2HT = 1.50 max
NB Voltage = 1.45 max
SB Voltage = 1.55
CPU VTT Voltage = 1.40 max
Good luck. and keep an eye as always on your temps, you can fry an egg on the NB as im sure you know.
found some Q6600 OC
http://www.xtremesystems.org/forums/showthread.php?t=159457
http://www.xtremesystems.org/forums/showthread.php?t=127331
You will not get a Q6600 much above 3gig (1333 or 1334 FSB) on a striker extreme.
You will need to uprate the northbridge cooling, increase the NB voltage by +0.1 - everything else should run at stock voltages ok.
Better yet do yourself a favor like I did:
and get a real motherboard.
^^ haha, i remember that thread, maniac! ;)
Its been a really good mobo for me. But you do need some patience to clock it.
I spent quite a bit of time to get my Q6600 to a 3gig overclock and hours to get it to 3.2gig stable on that board... swapped for a P35 board and it did 3.6gig stable with a little tweaking, swapped for a P45 and it went straight in at just shy of 4gig... then went to the 750i board where I managed 3.6gig with a LOT of tweaking - but now dropped a Q9550 in the 750i and it went to 3.825gig no hassle and can manage over 4gig but that requires too high voltages due to the vdrop/droop with the nFail chipset :(
