- 12 Jan 2010
Hi All,
I am new to this site and this is my first build and overclock. Through various forums I have altered various settings and have arrived at a quandry. I can only overclock to the amount I am if I keep my ram timings at auto, this gives me timings of 5-8-8-23.
The ram specifies 5-5-5-15 but I have no chance of achieving that.
My system consists of gigabyte ep45 ud3l board, q8200 cpu@490, Prolimatech cooler w/120mm fan and 8gb (4 x 2gb) Buffalo select Value Ram (667).
Can anyone give me any ideas how I may be able to tighten the timings, and will it make a noticable difference?
Cheers for the help and if you need any more info let me know.
Matt
Matt
defo look into getting some higher spec ram for the future
id do some lengthy testing on your ram for a few hours to check stability, it may creep in after the ram heats up.
