I'm about to build a new system and i'm wondering if the price difference between Q8200 and Q9550 is worth it?
From what I can tell the biggest difference is the 12mb cache on the latter.
I only care about performance in games, anything else is just gravy.
I will be overclocking (rather modestly (is that a word?
I have read some articles but none of the ones I have found comment directly on this subject, and just compare them at stock speeds, or similar, that makes it hard to decide which one is actually a better buy.
I'm guessing from the 50% price difference I'd want ~25% better performance. Is that unrealistic?
How far do these clock on average with stock cooling? (assuming a decent setup otherwise)
Thanks for any input!
).I have read some articles but none of the ones I have found comment directly on this subject, and just compare them at stock speeds, or similar, that makes it hard to decide which one is actually a better buy.
