Hi,
Could anyone recommend a cooling solution for my intel Q8300. I used setfsb and have managed 3ghz. 3.2 just crashed on me, 3.1 and the CPU fan sounded like it was working way to hard, although no crashes. I settled for the 3ghz and ran Prime95 for 2 hours with no problems or errors.
Temps are in pics...
And CPUz...
Both taken at the end of my Prime95 run. I know nothing about O/C'ing (mostly why I used setfsb), but from what I have read, the temps don't look so bad and the fan certainly didn't sound like it was working to hard at all.
I was going to remove the fan and clean the heatsink anyway, as there is a fair amount of dust and stuff in there, so thought I may aswell change it out and see if I cant lower those temps abit as a plus.
I have a stock Dell Studio, so my case is not large at all. I reckon I have 120mm of clear space to install a new cooling unit, even then it will be close to the case cover. It is a 4 pin connection to the existing unit and I dont really want to remove the Mboard to fit a back plate etc. Any Ideas for me??? Preferably something stocked at this site and easy to fit. Might be nice to have a new and better case fan too, thats 92mm and has 3pin connection.
If I clocked in another way, would I see a better figure than 3ghz??? but like I said, I wouldn't know where to start.
Thanks for any help.
And CPUz...
