- 11 Jun 2008
Just set up my new PC and noticed (using SpeedFan) I'm getting CPU temps of ~50c idle and upwards of 80c under load (calculating PI), core temps are about 20c higher (Core #2 never seems to drop below 72). I'm using the stock cooler, but after placing it I had to remove it to get my power supply in place. I put it back and used it for a bit until I read that after removing the cooler, you should reapply thermal paste, (also it was crashing "randomly"), so I scraped the stock stuff off (both the heat sink and chip) and put a horizontal line of bog standard thermal grease on (the shop was out of AS5). My case temp is 40c even though I've got two 1600 rev fans (inlet at front, exhaust at back). I read something about thermal grease taking a while to set - could this be it? Why are my temps so high!? (is 40c normal for a coolermaster elite 340?)
