Hello, I have my PC all ready to build except the CPU and Motherboard, now the Motherboard is in stock and so is the CPU OEM, I have done a little research and found the CPU OEM comes with no fan, no stickers no fancy things that you do not need if you have your own CPU Cooler.
By the way I want to buy the Ultra 120 Extreme which seems to be quoted as being the best air cooling solution available but I cannot find this anywhere in stock at anywebsite which is strange, so moving on, the OEM also has 1 year warranty instead of 3 years and I heard when its retail the CPU is thoroughly checked hence 2 extra years warranty?
Is there anything else I should know? I am really tempted to buy this but only if its the exact same identical CPU in every way but all I have listed and in no way would effect the lifespan?
Thanks, maybe someone who has brought it could share their views on it too.
