That's grand for the speed.
Temps look ok, ideally you want to stay below 75'c, youre unlikely to hit temps that high in normal use.ive only been running prime 95 for about half hour and my temps havent gone over 66c for the hottest core, the rest are 62-63
im i right in thinking i want to keep the temps below 70-75c?
i had a q9550 and at stock it was 40c under load, is it me or these quads run kinda hot?
got it to 3.2ghz and on load was 55c =/ cant go any further with ram and mobo i had![]()
