My custom built machine will no longer boot. It does not even get as far as the BIOS screen. It has worked fine for several months, but suddenly it will no longer boot. I have changed nothing on the PC and the CPU has never been overclocked.
It is a Q9450 and my motherboard is a Gigabyte GA-EP45-DS3P (both bought from Overclockers). All has worked fine for several months. When I boot up there is a blue diagnostic LED called Q9450 CPU_LED on the motherboard which continues to flash. This suggests a problem with the CPU.
I read on this forum about a Q6600 not booting up when it was cold. I tried blowing hot air towards the CPU but it made no difference. I've tried resetting the CMOS but no luck.
Do I have a duff CPU? Seems strange why it would suddenly no longer work. This CPU has always run very cool so I can't see how it could have overheated in any way. I presume the motherboard is OK. The only way to prove that would be to try replacing the CPU but that would be an expensive exercise if that turns out not to be the problem.
Should I contact OC support for a replacement CPU? I've tried contacting Gigabyte support for suggestions but so far no reply.
if you only have one cpu/board but cannot think of any others that will actually give you the answer that you need.
