Firstly, my specs:
Q9550
P35-DS4 Rev. 1
4x 2GB OCZ Platinum
I'm attempting to get my Q9550 E0 to 3.4GHz.
When I put the bus to 400x8.5 the PC boots into Windows etc. However after a couple of minutes the Windows cursor will stop moving, but I still have the control (i.e. I have to control it blindly). Everything works on the PC, programs start up etc. it's just the mouse that goes a bit strange. I haven't tried Prime while it's running at 3.4GHz, but it'd probably fail.
My best guess is my NB voltage is too low. The 'maximum' supported FSB for this motherboard is 1333MHz, I need it to be running at 1600MHz.
Any suggestions on what I should try first? How much should I up the NB voltage by?
Thanks,
Craig.
Q9550
P35-DS4 Rev. 1
4x 2GB OCZ Platinum
Thanks,
Craig.
