Q9550 E0 Temps
28 Jun 2005
Just received my Q9550 E0 stepping today and when I looked at the temperatures I've noticed one is stuck at 42:
Is this normal?
is common on the chips. mine has two stuck , 1 and 4, 1 is 35, 4 is 40.
as long as they show if it getts hotter, then its not really an issue i guess, just annoying.
Thanks real temp says that one of my sensors is stuck.
The temps on real temp and core temp are different
Which one is accurate?
IIRC core temp, RT i about 5 degrees off. As per the original point, one my my sensors is stuck too, core 3, seeing as it was the coolest running before the sensor stuck I'm not too bothered, as it will more than likely be the coolest core. Would be a pain if core 0 or 1 got stuck though
- Pea0n
