What is the default gtl settings for a 45nm quad, im currently running my q9550 at 3.8ghz, on a very low vcore, all gtl's on auto, gonna bump the fsb to 471, ive heard i may have to work with gtl's at this speed. Any advice appreciated
Thanks for the link.Read this guide
Read it, understand it, read it again, try some settings and test, then tweak based on that. Reading through the thread will help as a lot of people have posed questions, certain setups etc that may help you with stability.
GTL refs are all about tweaking though
Yep i had a read through that one as well, very good thread.The thread PaulyD has linked helped me a fair bit, iirc there's a Q9550 thread somewhere on that forum too, worth a read setter![]()
Im using a TRUE black with 2 1200 rpm fans in push/pullWhat cooler are you using with your Q9550?
