hello guys, Im having trouble with ocing this right now.
Main issue is I haven't been building pcs for a long time and I don't understand a lot of the bios items.
Right now, I am using a Q9550 , Maximus X38, 8G Corsair 8500
Can log in normally with fsb at 400, but right now, it seems that no matter what Vcore I use or etc it won't boot properly.
Any help in the bios section would be great. Was hoping to achieve between 3.6-4.0. Also, even though the Dram frequency is showing as DDr-1067, in cpuz, it is showing as 550. Whats wrong with the ram setting?
Cpu Ratio Setting : 8.5
FSB Frequency : 444
FSB Strap to NB : 333 ( I read that it has to be 1:1, but I don't seem to have this option... )
PCIE Frequency : 100
DRAM Frequency : DDR - 1067
DRAM Command Rate : Auto
Drramt Timing : Manual 5-5-5-15-3-62-6-3
DRAM Static Read Control : Auto (what does this do?)
Ai Clock Twister : Auto (what does this do?)
Transaction Booster : Auto (What does this do?)
CPU Voltage : 1.3 (what is safe region?)
CPU Pll Voltage : Auto (no idea what this is for, what should it be?)
North Bridge : 1.51 (what is safe?)
Dram Voltage : 2.16 (Ram shouldn't be the problem so far?)
FSB Termination Voltage : Auto(again, no idea, what is this for?)
South Bridge Voltage : (Auto, what can it be?)
Loadline Calibration : Auto (what should it be and what is it for?)
CPU GTL Referemce : Auto ( what should it be and what is it for?)
North Bridge GTL Reference : Auto(same as above)
DDR Channal A Ref Voltage : Auto (same as above)
DDR Channel B Ref Voltage : Auto (same as above)
DDr2 Controler Ref Voltage : Auto (same as above)
SB 1.5V Voltage : Auto(same as above)
CPU Spread Spectrum : Auto (should this be auto, enabled or disabled?)
PCIE Spread Spectrum : Same as above
FSB Frequency : 444
tRFC timings set as 52 - rest it's ok.
