Hi all
ive been having trouble with the temperatures with my q9550 on a dfi lt t2r - all at stock settings, not overclocked. im using the stock cooler (in an antec p182). i have also had some packaging/heatsink trouble with the motherboard, but that will be addressed in another thread.
at ambient room temp of 20c the processor idles at around 45c (at stock!) and when put under load with prime95 ive seen it go over 80c (and over 70c in some games i.e dirt). ive been using ite smart guardian, real temp, speedfan and cpuid hw monitor to measure the temps (one at a time), as i cant seem to get any reliable info (ie they all report different results - including the bios).
80c for tcase under load is very concerning - while i was performing these tests i had cpu-z open which confirmed that the cpu's thermtrip protection came into effect as the multiplier went down to the lowest value of 6x - this situation shouldnt happen! i dont not wish to shorten the lifespan of this cpu.
i have checked and confirmed that the heatsink is correctly mounted and that contact is even.
tcase for some reason is about 10c higher than the various core temps - though ive heard this inversion of values is due to PECI not being supported/disabled by the mobo.
can anyone else who has the same configuration post their findings - does your rig run this hot? could the integrated heat spreader in the cpu be damaged? have i got a defective cpu?
cheers
fusi
cheers
fusi
