- 1 Mar 2009
Hi guys. Have a bit of a problem. Friend picked up a Q9650 with Asus Maximus II mobo and it's great. Just one problem though. I have a feeling the DTS sensors on 2 of the cores might be knackered as the reported temp on 2 of them is much much higher than the other 2 (and much higher than what they should be).
As you can see cores 1 and 2 report an idle temp of 67oC which is high (but both the cooler and cpu itself are not even warm (checked this by touch when I tried reseating the cooler). Another point to note is that when I reseated the cooler the pressure pattern in the thermal paste indicated there was full contact on the cpu. Cores 3 and 4 seem to be reported correctly. I have applied some
I'm using a Xigmatek HDT S1283 cooler with arctic silver.
So my concern is that when I'm playing games, even at stock, there may be times when the incorrectly reported temps exceed the TJ Max value and it starts throttling unnecessarily which is going to hit me on performance. Further to that it doesn't leave me with much headroom for overclocking.
Anyone have any good advice other than to live with the fact I'm not going to be able to get top performance out of this chip?
