Obtained a Q9650 today to replace what has been a very good Q6600. However i am a massive FSX fan, and every extra bit of CPU speed i can get helps.
Have got it to 4050 (450x9), and was wondering if you kind people could:
A: Please check i havent made any silly/dangerous settings (as i was tweaking some things that i dont know as much about asd i should)
B: If these settings seem reasonable, suggest any further tweaks that might help me clock this chip any higher (it all counts in FSX)
Realise the Asus P5KC could be a limiting factor here, not the worlds best board i imagine??
All settings are defaults unless stated otherwise (so probably at AUTO)
AI = MANUAL
CPU RATIO = 9.0
FSB STRAP = AUTO
FSB FREQUENCY = 450
PCIE FREQUENCY = 4101
DRAM FREQUENCY = AUTO
DRAM COMMAND RATE = AUTO
DRAM TIMING MANUAL 5-6-6-18
CPU VOLTAGE = 1.4
CPU PLL VOLTAGE = 1.5
FSB TERMINATION VOLTAGE = 1.3
DRAM VOLTAGE = 2.1
LOAD LINE CALIBRATION = ENABLED
NORTHBRIDGE VOLTAGE = 1.4
CPU GTL = 0.63
NB GTL = 0.67
CPU SPREAD SPECTRUM = DISABLED
PCIE SPREAD SPECTRUM = DISBABLED
C1E, vanderpool etc all disabled.
1.4V in bios is giving me 1.392v under load, is this too much????
Temps idle are 36-36-42-41
Temps under load are 54-49-53-54
Many thanks in advance for your help/advice
AI = MANUAL
CPU RATIO = 9.0
FSB STRAP = AUTO
FSB FREQUENCY = 450
CPU VOLTAGE = 1.4
DRAM VOLTAGE = 2.1
CPU GTL = 0.63
NB GTL = 0.67
