Hi,
I am in the process of upgrading from a Q6700 (overclocked at 3.3 gHz) and am wondering whether to buy a Q9650 or to go the whole hog and get an i7 2600K or 950 which means I also have to upgrade motherboard RAM etc (although at surprisingly little difference in cost given that I can sell my old hardware).
The setup would be as follows:
All the below would have:
1x GTX570
SSD 64GB
Windows 7 64
1)
Q9650
EP45-UD3R Gigabyte P45 motherboard
8GB DDR2
2)
i7 2600K
Gigabyte GA-PH67-UD3 Intel H67
4GB DDR3
3)
i7 950
Gigabyte GA-X58-USB3 Intel X58
6GB DDR3
I would be overclocking, not sure about the i7's but would hope to get the Q9650 up to 3.8 or 4 ghz on air.
I know the i7 is newer and faster than the Q9650 and my question is really whether I will actually see the performance gain from the i7 given the games that I play. The only reason I am upgrading (sad I know!) is my heavily modded oblivion runs at 10-30fps on the Q6700 (even with the GTX570 already in use) and any of the above three processors will improve this.
Oblivion being old isn't too bothered about quads/hyperthreading etc and I don't know whether I will get any noticable performance gain from an i7 (and if so which out of the 2600K/950 is best) as opposed to a Q9650, the only other game I play is Supreme Commander and the main bottleneck with this is other peoples pc's on the net...
My only other concern when if moving to the i7 is that I have a rather old (4years+) coolermaster case and am not sure if the socket 1155 or 1366 motherboard will fit in it.
Apologies for length of post, thanks in advance for the help!
1x GTX570
SSD 64GB
Windows 7 64
1)
Q9650
8GB DDR2
2)
i7 2600K
4GB DDR3
3)
i7 950
6GB DDR3
