Hi
Just purchased a Q9650 and a Zalman CNPS9500A HSF
Besides the hassle of removing the motherboard to fit the back plate (which also went on better when I put it on the right way round... plonker) and removing and re-fitting all components to allows me to do it (time consuming). All appears to have gone OK so far...
First thing I checked was the core temps (realtemp / coretemp) and at idle:
Core - temp
0 - 27
1 - 25
2 - 39
3 - 38
Slightly panicked!!! So re-fitted cooler, not easy when mobo in the case!
And idle temps pretty much the same after re-fitting.
Ran PRIME95 on all cores:
0 - 45
1 - 42
2 - 41
3 - 40
So looks like cores 2/3 do move upwards but always come back to 39/38
Question... is this a case of stuck "temp sensors"? and if so, should I worry? and should I be looking at an RMA here? I have looked at other threads but still a bit "twitchy" considering what the CPU cost!
At the moment the coolers fan is running full blast. Don't know why, as BIOS is set to control it Auto!? Starting to wonder if I NEED to use the fanmate that comes with it, or it just runs full tilt?
Core - temp
0 - 27
1 - 25
2 - 39
3 - 38
0 - 45
1 - 42
2 - 41
3 - 40
