Using coretemp...and I haven't set any offset for 45nm, so I think it is over-reading 5 degrees.
At idle with Zalman 9700 using AS5 (using a line across the chip per AS recommendations on their website)
38, 28, 28, 38
At load
55, 45, 45, 51
Don't these look really weird? I thought core0,1 were a pair and core 2,3 were a pair...so how come 0 and 3 are the hotter ones?
Just to make sure, I cleaned the Zalman and CPU again and re-applied the AS5 for a second time, as per Arctics recommendations...and got exactly the same result.
All of these temperatures are probably reading 5 degrees over due to coretemp and the wrong offset.....but it was the wide disparity between cores I was curious about.
38, 28, 28, 38
At load
55, 45, 45, 51
