Qestions about faulty PS3 consoles
25 May 2011
Hi I fancy buying a few faulty ps3 consoles from ebay to have a go at fixing, more as a bit of a hobby. Just wondering, lets say one of the consoles main fault is reading disks, can you just swap a blueray drive out of another PS3? Or will that not work as it will only work with the orginal drive?
Plan to bake the motherboard in the oven for YLOD
You can swap the bluray drive yes.
If you take a look on the various parts on the bay and look on google for what people do to fix Playstations you'll get a pretty good idea.
