Hello,
i need your help. My 2 sons both have Lenovo Lenovo Tab M10 HD Gen 2 tablets (output 5V 2.0A 10W, battery 5000 mAh). As children they are not careful and i want to avoid damaging USB-C ports (2.0).
I can buy through amazon ES (Spain), which should have the same products as the Amazon UK store.
I would like to ask you which (cheaper) Qi Charger do you recommend to me, in terms of quality and speed?
I've seen Qi Charger 313 on amazon.es, around 22€
Is it good enough for a quick charge (around 2 hours?)?
I also would like to ask which Qi Wireless Charger Adapters do you recommend, to install on these 2 tablets, that i can buy preferently on Amazon ES, and if they should work
"through" the original case, and through this one https://www.amazon.es/GOZOPO-Tab-M1...+infantil+para+lenovo+tab+m10+h,aps,89&sr=8-5
Worst case scenario, i stick them outside the cases, i really don't have time and money to burn on new tablets.
Thanks in advance!
Regards
Thanks in advance!
Regards
