QoS - Help setting up
Don
23 Oct 2005
North Yorkshire
Hey guys,
I have a Asus GS-AX3000 and want to setup QoS, currently I have this set:
Playing FIFA just now I did a speed test on my PC and got the following speeds, which are my top speeds I can get, so I'm assuming no priority is given to the PS5?
Should I go through the traditional route? I just want to ensure games aren't affected by numerous devices on the network downloading updates etc etc
Any idea what I should put in the below?
Or if you have any advise that would be appreciated
I use Adaptive QOS with manual speed entered, 20 upload and 210 download (this is on a virgin 200 mb which is 220 download and 22 upload roughly) the guides say use about 80% of upload and download and I also use the following custom options in this order:
Gaming
Video & Audio Streaming
Work from Home
Web Surfing
Learn from home
File Transferring
Others
Works very well, with one system maxing out upload and download pings still stay low unlike what happens when QOS is disabled. You might find cake works better, but i didn't use that as it has to disable hardware accelerated nat features, the same limitations happens with Traditional and Bandiwdith Limiter. Hope this helps
