Got my i7 to 3.9ghz so far, without touching anything but the vcore.
I am planning to go higher but judging by the threads here, there seems to be a point where increasing vcore alone is not enough. I see other voltages quoted, most commonly the QPI voltage.
I'm a bit of an overclocking noob so I have played around with it a bit, to see if it had any effect. I tried whacking it up to 1.3v from the default of 1.15V (i think) and all that happened was my stable system now failed to boot! This happened all the way down to low 1.2x V, so increasing it does not help me overclock at all.
So yeah, it'd help me loads if someone could explain why you increase the QPI voltage (are there any signs when it's too low?), how you increase it (do you go up in increments or just whack it up high?), are there any negative effects of a high QPI voltage, and if it's always necessary in achieving high (4ghz+) overclocks?
My mobo is a EX58-UD3R, if it makes any difference.
Thanks
Thanks
