i5 2500k /thread
i5 2500k /thread
Not really, you need a board with an NF200 chipset to get 16x/16x on a Z68 board with a 2500K.
But that's his only option regardless, AMD will bottleneck, ironically giving lower frame rates with the higher bandwidth.
EDIT : OP, the 2600k/2700k launched, but they're just hyperthreaded and higher clocked 2500k's, so it's not like there's a massive difference, Bulldozer pales in comparison for gaming.
2500k + decent motherboard and you're onto a winner.
I didn't say X79 as the 3820 isn't on OCUK yet and the hexcores don't fit into his budget.
A 3820 set up should cost around 500 however.
I thought 8 core CPU's where pointless for gaming given that no games are threaded for more than 4 cores anyway? Sure there is better bandwidth, but I don't see it been any better than a fast quad.....
