Exsomnis said:Quad SLi = pointless bottlenecking.
Do resolutions go that high?Defcon5 said:Possibly not if your playing at insane resolutions and force all settings to the highest they go
SLi/Crossfire is more than enough for that, see the post above mine. Even the FX-60 is knocked sick by the bottleneck in a dual-card system, quad SLi is crazy e-penis extension for people with waaay too much money.kdd said:Yes quad sli is intented for monitors like the dell 30" widescreen effort.
Exsomnis said:SLi/Crossfire is more than enough for that, see the post above mine. Even the FX-60 is knocked sick by the bottleneck in a dual-card system, quad SLi is crazy e-penis extension for people with waaay too much money.
Ah that's cool then.[ui]ICEMAN said:Wrong I'm afraid, having the luxury of both systems I can tell you Oblivion isn't playable at 2560x1600 on an FX60, 2x7900GTX SLI, it is however more than playable on the quad setup. At 2560x1600, in some games, trust me, the CPU isn't what's holding you back, if it was then when overclocking the FX60 to 3ghz, there'd be a performance gain, there isn't.
I'm stuck at a lowly 1280x960 but it looks pretty enough and a single card can push it easily. Can't understand why someone would spend so much.
Whatever floats your boat though, eh?
kdd said:I would imagine quad sli will be bought only by people to whom the money is a drop in the water so meh tbh. If you shelled out and bought one on credit or saved up i would say you were crazy.
