quad cooling help in a HTPC?
24 Jul 2007
Swansea, Wales
recently built a HTPC as my gaming days are coming to an end, happy with build however the fan on the cpu is the loudest thing on earth, can any one recommend a decent cooler than is quiet? price wise im not to bothered as theres no point in scrimping on a decent cooler
thanks in advance
A tower style cooler would work well, but you have to find one that'll fit in your case.
What's the clearance like in the HTPC case?
I'm running a Scythe Ninja Mini in mine - initially with the Scythe fan, then a Noctua 80mm, and now it's passive as it sits right next to 2x 120mm case mounted fans.
I am using a Scythe Mini Ninja in my Silverstone case which does a good job at keeping a E2220 cool passively, you might need to use the fan at low rpm as your running a Q6600.
