Quad Core CPUs
Permabanned
18 Jun 2007
Plymouth
If you had a quad core CPU, and a game only supported dual-core, leaving two of the cores doing nothing, does Vista have the ability to dynamically allocate resources being used in the background, other programs etc to the other cores?
Always wondered.
I must say that when I first went to a multi-core CPU I was a bit underwhelmed, I was sort of expecting 2x2800=5600MHz.
However, messing you soon notice that your PC still zings along on the desktop while you're unraring that 50GB backup, or encoding a DVD.
By the time you get to 4 cores, life really is a beach.
I'm pretty sure XP, Vista and Linux are all fairly on the ball with the alocation of cores.
Quite a common misconception. Personally I think the majority of multicore computer sellers on Ebay should be done for Trade's description. Mhz is never the sum of all cores. Could have a gazillion cores a 1ghz, and it would still be a 1ghz system.
But that said, for multi-tasking, and if you have multithreaded applications, a multicore system really does make windows fly.
Yeah :D
You see a add for a CPU advertised at 6.66GHz and its a P4D CPU its very misleading to an average user as you say the sellers need a good telling off.
