- 28 Sep 2004
- westmidlands
Hi guys,
I got round to fitting my new quadcore cpu the other day and i'm running at stock for the moment...but i'm concerned by the high temps i am seeing while using TAT, i am using a titan amanda heatsink tec to cool it....but i'm seeing temps of around 44 c whilst in windows, after running spycheck it went upto 62c....after 15 mins playing dark messiah was around the same...and i've just run orthos and it has risen to over 70c
I know the quad cores run hotter...but surely not this high especially whilst using the titan amanda?
I've noticed that the tec light is always on ...and thats as soon as the computer is switched on...basically it never goes off, and was also the same when i was using a E6600 cpu, do you think the amanda may be defective??
Really need some input on this....and would appreciate any help you can give me.
The specs of my system
Intel Core 2 Quadro Extreme Edition QX6700 "LGA775 Kentsfield @2.66GHz
Asus Commando Intel 965 (Socket 775) PCI-Express DDR2 Motherboard
2gb Team Xtream Ram @ 4/4/4/10
EVGA GeForce 8800 GTX KO ACS3 SILENT 768MB GDDR3 HDTV/Dual DVI graphics card
Enermax 1000w galaxy psu
Titan Amanda tec / heatsink
Xfi extreme gamer sound card
Akasa Mirage 62 case / Scythe S-FLEX 1600RPM Ultra Quiet 120mm Fans - 3/4 pin
Samsung dvd re writer
Western Digital Raptor74gb
Samsung spinpoint 80gb
Thanks in adavnce.
Thanks in adavnce.
