Read their mechanical and thermal design whitepapers and find out.![]()
Hows the phenom compare generally
I use the multi drop and thats fine. The voltage drop would make it unstable I think, Im not sure it works with overclocking?
Is that what you use with yours, I have the same board and cpu.
I just checked and eist and c1e was allready on
Without auto voltage on vid the above is disabled. Obviously it wont boot to 3.4ghz unless I set the cpu voltage manually and even turning +100mv to auto resets it on windows load. No go :/
