Hi,
Fitted my first intel CPU in quite a while today - a q9550 retail version.
A couple of questions - do the retail pack coolers differ between batches? The one in mine seems very low profile for a quad core cooler (stands about an inch high and is well below the level of the heatsinks on the Asus P5Q board) - my brothers E6600 cooler is a lot taller/thicker and its only dual core...
Been keeping an eye on core temps, and 1 core seems to run a fair bit cooler than the rest (by several deg's often when under load), whereas core 4 always seems to be a couple of degrees higher than the rest - do the quads tend to have varying core temps, or should they generally sit at the same temp when idle if the cooler is sitting correctly?
Upped it to 3 ghz for a slight oc, but don't want to push it without getting something to replace the lightweight retail cooler.
