Quad Core, to upgrade or not?
8 Jan 2007
London & Dubai
I currently have a Q6600 (G0) @ 3.6GHz, (will do 3.8, but I'm happy with 3.6).
I have the opportunity to upgrade to any one of the following at relatively low cost.
Q6700
Q9400
Q9450
Q9550
Do I upgrade or shall I stick with what I have?
Will any of the above chips be faster than my Q6600 clock for clock?
The Q9xxx series will be faster than your Q6600 clock-for-clock. Plus they're 45nm so use less power for higher clocks.
Going from a Q6600 to a Q6700 is as useful as an ashtray on a motorbike tbh.
Still, I would recommend just sticking with your Q6600. I know personally they are pretty good at 3.6, you wouldnt see enough of an improvement out of a Q9xxx to warrant the cost tbh.
Upgrading from Q6600 to Q9550 will cost me about £60
Given current cost of 9550 ,that would be a good deal.
If you got a (semi) decent clocker the newer cpu should run @3.8 and with larger cache might run things a little faster. It should also use less volts (might take you a bit to recoup the extra £60 though) and run cooler/quieter.
Overall would agree with jrwagh333 - then again it's something 'new' to play with and there's the possibility of '4ghz' etc.
Personally although my head says forget it - in your position I'd buy the Q9550 :D
Don't listen to me though - the fool who bought a 8400 to sell it 3/4 weeks later and buy a Q9550.(the 8400 was a good cpu as well ; just could not resist the temptation of a quad - fool - No regrets though :D)
NO point man i have q6600 at 3.8 ghz+ and it handles anything u trow at it is gpu that needs constant upgrade not cpu, upgrade your gpu instead
