quad core water cooling
14 Oct 2003
South Derbyshire
im looking into water cooling my qx6700, as air cooling doesnt cut it for me.
anyway, i want an external box which will sit above my pc by about 300mm
i was thinking of using 2 pumps to take the load as the water setup wont be inside my pc.
what CPU block should i use for this? whats the best for a quadcore setup
it wont be cooling chipset or GPU [not yet anyway]
Ok better way to do this,buy a swiftech rad box that way you can mount it on the rear of your case and use the pci slots to get the hose in,or you could drill 2 hole`s.
Cpu block for the quad my choice D-TEK FuZion i run one myself with my E6850.
Pump wise you only need one good pump say D5 of DCC with a plexi top,with these pump`s if you do put more in the loop at a later date they will still be up to the job.
