Quad Cores
19 May 2005
What time next year are they coming out?
Will they be much more expensive than Dual cores?
Will Dual core come in down in price by much?
Clovertown / Kentsfield Intel Quad Cores are already out in the market - not really worth the investment right now.
It hasnt brought the price of the Dual Cores down as of yet, as the Quads are stupidly pricey.
If you got the money for one I would splash the cash :D
Depends what you are planning on using it for...
Intel's offerings are out atm but AMD's are coming next year in the first quarter iirc.
i think amd are gonna get it right like they did with the x2 . intel are doing exactly what they did with there first stab at dual core
I had a quad qx6700 and went back to an x6800. I never really used all 4 cores and found no real benefit (except maybe 3dmark), but lots of disadvantages.
For starters I am sitting here with an x6800 with a mild overclock to 3.3ghz. TAT and CoreTemp show this idling at an unbelievable 29 degrees (in a cold room I might ad). Hard to believe. And running Orthos over 5 hours I never saw it once go over 54 degrees in a warm room. On the Quad, at 3.3ghz, all 4 cores idled between 40 and 50 degrees. Running Orthos on just cores, and 2 of them would hit 80, the other 2 - high 70's. I had to turn up my Tuniq Tower from 1250rpm to full speed to get any drop in temps worth talking about. I also found clock for clock the x6800 was faster in benches. I have read this is down to the way windows deals with multithreaded programs and also overhead having to handle 4 cores. Anyway, am glad I was able to swap my quad for a mates x6800. I am now overclocking like mad and 3.6ghz is 2 hours stable in Orthos right now. Still has not broken 55 degrees.
Regarding native quad core - not sure how this is going to work. But had a Precision 490 workstation on loan from work. This had 2 x dual cores (Xeon 6150's) and only for the poor latency on the FBDimms would have been a screamer. Each cpu had it's own dedicated 1333 front side bus. So effectively I had quad core with 2 front side buses. As far as I know the current quad cores on desktops share the same front side bus as it's 2 dual cores stuck together. So when people talk about native quad core maybe they are talking about dedicated buses for each core or each dual core.
