Okay, I'm looking to spec up a 48-core system, comprised of four 12-core Xeon E5-2600v2 processors, and as much RAM as possible. The system is for running large-scale parallel simulations - intended as a stop-gap between a regular desktop machine and renting time on a cluster.
I know that there are some quad-CPU boards around, but I haven't seen anything (yet) that's rated specifically for the 12-core 2600v2. For example these intel boards look pretty attractive, and 48 DIMM slots would be ideal, allowing up to 384Gb of RAM with standard 8Gb modules - which should be plenty. Unfortunately the board is, apparently, "only available in integrated systems".
Does anybody have any experience using quad-CPU boards? Any way to buy the board directly? Any support yet for the latest Ivy Bridge E Xeon processors? I've checked supermicro, and they don't have anything listed yet...
Mounting in a desktop machine could also be an issue, but with all the custom case designs around I'm sure I could find something to accommodate.
Ideally this machine will be water cooled, but that's another matter (depends on finding a sufficiently large case really!).
