Q6600 July 2007 changes from B-3 to G-0 steppings
http://intel.pcnalert.com/content/eolpcn/PCN107463-00.pdf
CS||nuTs said:My mate has a G0 QX6850 and it does 3.7ghz quite easily on air.
Justintime said:
PinkFloyd said:
I want badly.
Is that an engineering sample?
Deluxe1 said:What advantages will this new stepping bring?
waso_dude said:that is crazy!! temps won't be a major problem again
dokko said:Azza can i just ask it that desktop (icons) a set profile for overclocking and modding?
3d Mark 01/03/05x2/06
CPU-Z
Super PI x 4
Crystal CPUID
Clockgen
SIS
Orthos x2
Plus whatever else is hidden!![]()
oweneades said:They look like normal short cuts to the programs to me. (I may be looking at something else though - I take it you mean the icons on the desktop from the screenshot)
Azza said:Basically they will run at a lower voltage so there is less heat. But becuase of the lower stock voltage there will be massize overclocking potential.
Devious said:If that E6550 is showing 52Deg in A.I booster then you can bet TAT would be showing the cores to be in the high 70's / 80's
dokko said:Aye i do.
I meant was that a separate windows profile (like an admin account) or is he just totally mad and enjoys OC a bit too much![]()
Klo said:Is there actually any advantage if you don't plan on overclocking, like the majority won't.
Azza said:Im pretty sure that A.I. booster is actually pretty decent at temp monitering. Also if it was rubbish i think he would use something different to show the temperature.
