I'll bear that in mind, for the day i loose my marbles haha!SiriusB said:If you like you can give that quad setup to me and I will get it folding for ya![]()
Mattus said:A lot of us run VMWare under Windows in order to run the Linux version inside a virtual machine. You'll be well inside the top 20 folders with that system![]()
The only problem being that for a quad you have to run two instances of VMWare to make use of all 4 cores since the free version of VMware can only use 2 cores max - still works but of course it's likely a bit demanding on memoryMattus said:A lot of us run VMWare under Windows in order to run the Linux version inside a virtual machine. The points are still a bit better than the Windows version, and it's a lot more stable.
BillytheImpaler said:The client/cores are more stable and there are fewer poor performing WUs like the dreaded 2610s.
MajorPart said:Will 2GB be enough to run all 4 cores then?
