Quad Rad for 900D
3 Oct 2013
UK
Hi im going to be getting a 900d soon just needed some help with what Quad radiator best for cooling but works well with low speed fans?
and cost around £100
I have two sr1s in my 900d. Brilliant rad almost silent with scythe gt 1450s on them. You really have to listen closely.
Will advise two right angle fittings for the bottom rad next to the psu.
(If you put the rads ports towards the front of the case the front fan bolts get in the way (might of changed now) with the ports towards the rear of the case its quite tight next to the psu.).
