quad rad in a Enthoo Primo??
A slight warning, some manufacturer rads are too wide for the front part of the bottom compartment, (like a few mm). But ex. alphacool and EKWB's rads do fit so if the rad you use are not wider than those you are good to go.
Thanks
Thanks, do you know of any rad that will 100% fit in the bottom, then i can buy the same or one to the same spec
