Hey all,
MY school approved the funding for the project, so we are go!
Got a budget of £2000, so thinking a Quad socket G34 board is the way to go!
Got a few quotes, cheapest I found was £1573 for the board, 4 processors and coolers.
Then, 32GB of RAM talkes us another £100 up (or £160...depends if I want to trust the OCUK ValueRAm :S)
750W OCZ PSU should be enough.....not sure about whether it needs 4 CPU power lines?
Getting a hard disk/disk drive from an old machine.
Might put my old 4870 in it, so there's some nice animations going on for the governors to look at...unless it's a massive performance hit
Then the case......currently I am going to be making this myself, from Acrylic/Aluminium. Should be able to make something which has nice airflow then...might even make ducting to go over the CPU's....depends.
Also, does this mean that I will need to run 32 instances of the CPU client (32 cores)
Will post a build log when I get further along the line in the build....
