- 27 Jul 2015
As above. Looking at the 3200 MHz CL 14 kit at £420, the 3600 MHz CL 16 kit at £429 and the 4000 MHz CL 18 kit at £450.
Specific questions:
1) Will the faster clock speed kits be able to down clock to the tighter timings of the lesser kits: So for example, will the 4000 MHz kit almost certainly be stable at 3600 CL 16?
2) The 3200 kit has lower latency than both of the slightly more expensive kits for most primary commands, except "Time Row Active" / TRAS. Is there any good reason you would pay more for the higher latency, faster clocked kits?
3) What are the Command Rate latency ticks for these modules. If it does not say, am I safe to assume that it would be TCMD = 2?
Any general advice on the best choice. Thanks a bunch in advance memory guru / fellow geeks.
Specific questions:
