Hi Guys,
Spec:
Shuttle sx48p2
Intel Q6700 2.66ghz @stock
Corsair XMS2 DDR2 4gb PC8500+
Intel X48 chipset
I've just built a new media pc with the above spec but I'm having some trouble with the cpu. Using CPUZ the cpu is displaying a core speed lower than it is rated at stock and this is with default settings - haven't seen this happen before:
I manually set the vcore to 1.30 and Tried changing the multiplier in the bios to get it back up to stock (8x333), but nothing happens. Managed to get the RAM running properly at 5,5,5,15 @2.1v - this is reflected in CPUZ.
So although my new settings are saved in the bios, they are not reflected in CPUZ - is there something in my bios thats stopping my changes for the cpu being reflected?
I've looked through the bios for some form of power management option that may be throttling the cpu, but there doesn't appear to be any such option.
I don't really want to overclock the cpu (at the moment anyway), but running at stock would be nice.
Appreciate any comments, even just to tell me I'm being a noob.
n
Spec:
Shuttle sx48p2
Intel X48 chipset
n
