This is the only online game I play now - I use the unpatched version as there are fewer servers to sift through. Used to be fairly good, but just haven't played as much recently
I tend to go on Instagib/Freeze Rail matches and there are a few clans out there still (there are a lot more on the 1.32 release though)
afaik, if you play unpatched (initial release) the master server list doesn't authenticate any CD keys, so you don't even have to put a CD key in to play online or offline. It just works.
However, the cd key authentication is turned on by default in the latest 1.32 release along with PunkBuster, so you'd need more than likely need to put a valid one in then.
However, not all servers on 1.32 are configured to block invalid/not present keys. I believe the server side console command to turn CD key authentication on and off is
