mks2005 said:
Hey,
Looking to purchase a pair of fairly high quality headphones.
- Primarily for listening to music.
- Will occasionally be used for music production. (I have studio monitor speakers which I use primarily so this isn't ovely important.)
- Needs to be OK for gaming, not overly fussed if it's not amazing though.
- Budget: £80-£150 or there abouts.
Was looking at the Grado SR125, which seem like a safe bet.
Any insight/recommendations are much appreciated.
How do you like your music reproduction? Do you like it forward and upfront. Linear and meutral and clean sounding or do you prefer a tonally warm or dark headphone.
For music I use Rs-1's and Senn he90's for games playing and watching movies I use Audio Technica's and the senn he90.
Fish99 is right about the grado presentation for music. Grados have a typically less soundstage width and the depth perception is 2d.
They are popular due to the fact they have very energetic treble which makes it great for rock. But some people have found this can prove a fatiguing listen. The way to get round this is to use flat pads or to reverse the bowl pads that come with it.
What does this do? Well by doing this you take a little of the treble off. Increasing bass. Sounds like an ideal solution, doesn't it.
There is a downside to this. By doing this you decrease the soundstage width even more. Also bass becomes more evident with more bass impact. By this I mean you feel it slightly more than using the pads that are supplied.
You can easily alter the sound slightly without any cost.
If you have a set of grado's from the 125 upwards they come supplied with what's known as bowl pads. Just reverse them. I.e pull them off and stick them on the "wrong" way round.
But yet even though this might help alleviate some of the sound issues one thing remain certain. No matter how much people try some people can not get use to the way grado's sit. they rest on your ears and the pads are a little abrasive. It not like a senn where it surrounds your ears but sits on top.
Also there a different Grado's.
There is (takes deep breath) sr40, sr60, sr80, sr125, sr225, sr 325, sr 325i, Rs-1, Rs-2, Hp-1, hp-2 hp-3, Ps-1, sr 100, sr200, and the latest model gs-1000
As for allessandros Ms-1, ms-2, ms-2i, ms-pro.
Some of the above have ceased production and are very desirable and rare.
